I have scorpion 2" lift spring on at present.But after fitting some STI struts all round the ride height has gone up 1" front and about 2" rear because the spring platform is higher on the STI struts.
The scorpion spring are OK but to soft.
Does any one know where I can get some stiffer standard or +1" ride height springs in the US????
Cheers
Chris
Rally springs
greg donovan
JasonGrahn
greg donovan
just talked to tein. he didnt really know if it would work or not. he didnt really seem to want to help me as i wasnt buying the 2 grand worth of gravel dampers.
but he didnot know the length so he thought that it would lower the car if you used anything other than the gravel dampers.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
JasonGrahn
