at idle and above. Not your lean miss, it's more like pulled a sparkplug wire off miss !! Only when hot after driving then sitting for awhile. New Plugs, Fuel Filter, PCV valve, injector cleaner. It seems to be #1 cyl. I pulled off the wires at the coil one at a time, #1 makes no diff. Ohmed the wires all OK. Ckecked plugs OK. checked injectors OK. Started it up, runs fine !! Aaaaarrrrggggghhhhh !!!!! it's driving me nuts!!
Oh yeah, it's a 90 Legacy wgn. Auto trans.
Intermitant dead miss
pull the wire off the plug when this is happening and stick another spark plug on the end of the wire. Best done in a dark garage or at dusk.
if the plug isn't sparking (remember to ground the plug body to metal) and you don't see any sparks flying around the other end of the wire, then there must not be any spark or it is not making it through the wire. bad wire or bad ignitor
ohming wires will tell you if one is really bad but not much more
- Title Whore
since you know how to check the juice running thru all that stuff, see what you've got running thru the injectors... try this thread:
http://bbs.legacycentral.org/viewtopic.php?t=17944
What kind of ignition do you have in there? try another ignition system.. new coil maybe? Spring for the upgraded Diamond Coil Pack. That can be found on 5MTs and Turbos. rare on an NA Auto.vrg3 wrote:Yes, the ignitor is basically two big power transistors, but it's just responsible for ignition, not the injectors.
The injectors are driven directly by power transistors inside the ECU.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
- Title Whore
