Then they found i had some unpaid tickets, an MIP, and some other little things. SO i got to stay for a while.
Well when i got out the weather had turned cold. Now my lovely drivers window is screwed up.
Whenever I try and roll it down it goes about an inch then stops. It looks like the little rubber piece at the bottom of the window is getting folded up.
It pulls the entire rubber guide on the bottom into the window.
This may be because I have tinted windows, it was wet, and I have taken that door off about a dozen times to work on the speakers.
Has anyone else had this problem? Or found any fixes for it?
Thanks guys, I missed you all.
