duty solonoide c wire color
sigkrist
Post by sigkrist »
Hi i got a Leagsy 2,2l 1991 autotrans with fwd and computer controlled awd
Any one can tell me the color of wire that connects to duty dolonoide c (locks in awd)
my legasy is not going in awd just fwd and i was hoping to test if solonoide is ok or maybe try to manually put it awd.
i got no codes from tc (done all the testing)
chanced fluid and filter
is there any way a autotransmission oil impruvements stuf is clocking up my awd clutch)
or some presure leaks in transmission
some times when starting car in park it sems like engine is having a hard time but if i put it in neutral and back in park its running smoth
like some valve or somthing in transmissin is stuck or cloked
Sigkrist
Legasy 1991 4wd 225k (EJ22 year 1993) (gone) 257000 km
Subaru E12 Libero (Domingo) 1996 (sold) 87000 km
Subaru E12 Colombus 1991 (current) 92000 km
Chrysler Voyager V6 1994 (current) 127000 miles
You can test the duty c solenoid at the TCU to see if the TCU is putting the correct voltage out, and also test it with the car off and check for continuity.
here's the tcu I/O page
http://www.main.experiencetherave.com:8 ... _page1.jpg
http://www.main.experiencetherave.com:8 ... _page2.jpg
These scans tell how to test the solenoid
http://www.main.experiencetherave.com:8 ... _diag1.jpg
http://www.main.experiencetherave.com:8 ... _diag2.jpg
91White-T
Post by 91White-T »
Don't do it. I tried this in my old SS and it was not good. Especially if the trans. is not doing well already
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
sigkrist
Post by sigkrist »
Thks
ill test the transmission AND se what comes out of it
thks guys
Sigkrist
tris91ricer
Title Whore
Post by tris91ricer »
I'm confused.. you've got a separate doodle to engage your AWD? What are the specifics of your computer controlled AWD?
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
91White-T
Post by 91White-T »
He's talking about the signal wire which connects the TCU to duty sol. C. If the TCU doesn't see a signal(ie. the wire is cut, or sol. c is not working)it automatically goes to 50/50 split. This is VERY bad for low speed turns as everything will bind and make horrible noises.
Traemand
Post by Traemand »
Hi Sigkrist,
Same problem in Denmark. Will get back to you when i have a solution. Took my tranny apart this weekend , soli C changed- but still locking up on turns. I`ll chek the wireing next week. I have some good pictures of the inside of the transfercace, and i am sure that`s where the problem is.:(
