A/F gauge freaks out in mornings
				LegacyPunk
so....recently when ive started my car in the mornings my air fuel gauge kinda freakes out and all the LED's flicker at the same time, it then goes away after a while. Im just wondering is this could be a sign of a failing O2 sensor or something else? or is this just part of the "Millenium Falcon Syndrom"?
							:twisted::cool::twisted: "Plenty of time, to ruin my life, so why start now?" The Movie Life
1993 Sports Sedan, Exhaust, MBC, 02 WRX IC, KYB GR-2s...Now with old back seat!
All the LEDs flicker at the same time? Normally only one LED is on at a time, right?
How cold are your mornings? Most of these "air/fuel ratio gauges" are based on cheap consumer-grade LM3914 chips that are only rated down to 32 degrees Fahrenheit.
				LegacyPunk
not that cold yet, I was just wondering if it was a cause for any concern.  All of them flickers a tiny bit for a while untill I drive around a bit, might just be a connection thing. Im not too woried about it.
Mine will do that too from time to time.  But it's quite rare.  Maybe it's condensation causing some electrical noise.
I have a question for you (or for anybody else who cares to reply) related to your A/F gauge. When you accelerate hard enough to reach positive manifold pressure (boost), does your gauge immediately show rich? Or does it continue to bounce back and forth like the ECU is still in closed loop mode? In my Legacy, quite frequently, I can be making 5psi or more of boost, and the A/F guage responds like the ECU is still in closed loop mode. Furthermore, I can feel the engine hesitating in time to the fluctuations on the gauge. I think my manifold pressure sensor is flakey and it's not telling the ECU when the engine is making boost sometimes. But I don't know what the proper response from the ECU is supposed to be to boost. Is it immediately supposed to go to open loop mode, or is there some other parameter combined with the MAP sensor before it will go into open-loop.
I hope I'm not hi-jacking your post.
Nigel
'94 Legacy Turbo
Nigel
'94 Legacy Turbo
Nigel, are you using stock boost control? I sometimes see similar effects when not using stock boost control. My guess is that the ECU wasn't designed with the idea of boost at small throttle angles in mind.
				The Scooby
