Files/images changed on server
I've restructured the images on my server. I was going to search through messages for the url, but apparently the search function doesn't search links.
Anyway, if you see a message from me, or a message that is linked to my site with a red x, let me know and I will fix it.
Couple other things, for those that didn't know. Here is a list of the FSM scans I've done, good tech info.
http://www.main.experiencetherave.com/s ... ual_scans/
I have indexed my image directory, so you'd be able to see what files are there, I'm a little unsure if I want to post it though.......I'll have to give it some thought.....
I just searched 1800+ posts ;)
should've found most of the links I posted, but if someone else linked to my server, the link will need to be changed.......like I said, let me know if you see something not working.
