Shifty Window
Subaru_Nation555
Shifty Window
All four windows on my '94 Legacy are loose, as in you can shake the glass back and fourth then the door is open. So this weekend I took off the door panels and tightened up the two window brace things on each door, I think the Haynes manual calls them stabilizers. This helped the problem a little bit but they are still loose. Is this just an inherent train of Subarus "frameless" windows are is there another problem I might be missing? Thanks.
'06 Impreza 2.5i wagon
It's normal for the windows to have a little play in them
