Throttle Body Boring
Subaru_Nation555
I was browsing boxer4racing.com yesterday and they had a bored out throttle body for $185. I'm not actualy considering this, I was just wondering if anyone has tried this mod and if it works?
'06 Impreza 2.5i wagon
tris91ricer
- Title Whore
Rev-Lab (http://www.rev-lab.com/) does it. They have pictures of before and after if you pick any of the chassis and then look under Power. I can't tell if they switch the butterfly, or just port the entrance and have it taper down to stock size at the butterfly.
Yes, if you bore it out, yes you will need a new throttle plate.
Subaru_Nation555
tris91ricer
- Title Whore
Wouldn't the issue be to bore it out if your intake could pull enough air to mak the throttle body the weak link?
Our throttle body isn't the weak link in our intake track is it? Even if we put on a cone filter, our limit comes from our MAF, right?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
scottzg
I think the throttle body is the last thing that restricts. the maf, the intake manifold, the airbox, and the heads themselves would all become restrictive before the throttle body. Although im not certain on this one, i can say with some confidence that having a disproportionately large throttle body makes it difficult to modulate power. Maybe someone would confirm?
FWIW, this is directly from Rev-Lab's site:
Sounds like it is indeed the last thing that is done, when you're trying to squeeze that last little bit out of the engine.This is only suggested when turbulence in the throttle body becomes the next step in optimizing your intake flow. (usually done after the exhaust, heads, etc.)
are they compatible?
i'm thinking of: coffe mug mode, changing intake manifold & thottle body (if necessary) and switching pulleey (just lighter, not underdrive); after i change al that, reset ECU, leave it to learn everithing from scratch...
Could this work on my EJ22 engine? (unfortunately there are no EJ22T in Europe...
ehm..
Is it wise to mode engine with 250.000km (155275 miles) on it? Engone (so far) works like swiss clock... no problems at all... average milage is about 111,5L/100km (20,4 miles per galon)... oil consumption about 1 litre/10.000km, top speed 130 MPH (not legal even in EU
QuickDrive
- Lurker-King
I'm not sure that the coffee mug mod will work on the Ej22 non turbo.
As with modding an engine with 150k miles on it, bolt-on's shouldn't cause any problems with reliability if it's running like clockwork.
Keep bringing it up to 130mph and I can sense that clock losing the second hand though
R I P-------- 91 Turbo 4EAT --------R I P
