Turbo Tranny ?'s
Turbo Tranny ?'s
what are the gear ratios of turbo legacy 5 speeds? do they have the reduction gear thing like WRX trannys do? thanks,
jake
jake
1st: 3.545
2nd: 1.947
3rd: 1.366
4th: 0.972
5th: 0.738
Reverse: 3.416
They don't have the weird split thing that the WRXes have; the center differential's outputs are both at the same ratio (so you could say the center diff is 1:1) and both the front and rear differentials have a final drive ratio of 3.900..
2nd: 1.947
3rd: 1.366
4th: 0.972
5th: 0.738
Reverse: 3.416
yeah the 3.90 auto & 3.90 mt rear ends are interchangable.
- Title Whore
yes i will have an extra auto hanging around.. but its from my turbo. i'm (hopefully) swapping it out because the auto is leakin tranny and gear oil
so instead of fixing it i'm just going to swap to a 5spd a little earlier than planned.
- Title Whore
I'm confused on the differences between the SS ratios vs WRX ratios.
This is what vrg3 said the SS ratios were earlier in this thread.
1st: 3.545
2nd: 1.947
3rd: 1.366
4th: 0.972
5th: 0.738
Reverse: 3.416
According to the FAQ on NABISCO, WRX ratios are are the same, except 1st gear is 3.454. Is this true, or is there a misprint somewhere? The reason I ask is I was under the impression all the ratios were totally different. What gives?
1st: 3.545
2nd: 1.947
3rd: 1.366
4th: 0.972
5th: 0.738
Reverse: 3.416
The WRX FSM states that's what it is.....whether that's correct....I don't know.
Also...it states the WRX reverse gearing is 3.333
There's quite a few ratios that are the same. But...as you may have found....subaru likes playing with things, and tweaking it here or there, so there's no real "standard" to anything.
