Anyone tried any Energy Suspension bushings?
IronMonkeyL255
Post by IronMonkeyL255 »
I was looking around at my local Autozone, and noticed they had universal Energy Suspension polyurethane swaybar bushings and endlinks.
They were fairly inexpensive (less than $20), so I was thinking about trying these out. Anyone tried these out before? Am I to be the first?
I checked out their website and saw they don't have a greasable 18mm bushing, but they do have a non-greasable version of that size.......
Rio Red '91 Legacy SS
Post by BAC5.2 »
My neighbor is running Energy rear sway bar links and Energy front sway bar links. They are beefy.
From my experience, Energy stuff is really nice. Compliant enough to reduce some noise, but stiff enough to increase performance.
IronMonkeyL255
I may have to give those a try, then.
I'll report back with part #'s and whatnot if I do.
professor
Post by professor »
non-greasable polyurethane bushings can be lubed with "personal lubricant" that is water-based. Safe for latex... safe for urethane. Glide works much better than KY for what its worth :twisted:
It won't last as long as regular grease, but you cannot use regular grease with urethane. I hate urethane squeaks
astv5l
Post by astv5l »
Which of these bushings can be used on our cars from the WRX kit?
http://www.energysuspension.com/pages/subaru.html
'93 Legacy SS 5MT
90LegAWD
Post by 90LegAWD »
i have installed a full vehicle bushing kit on my old civic.
i used the lithium grease that came with them, and only applied the grease lightly. i never greased them after initial install, and i NEVER had a single squeak. not even one. i even drove it during a michigan winter too.
it was a tedious install, but WELL worth it. after 200k+ miles, the OEM stuff was all gone, and they restored the chassis to better than new feel. combined with a stiff suspension setup, the car felt like it was on rails
WRXdan
Post by WRXdan »
I had them on my autox camaro...they are nice! But mine were grease-able if I remember correctly?
When I start messing with the brakes on the legacy I might re-do the bushings.
92 Turbo Legacy 4EAT
02 WRX - lightly modded (Gone but not forgotten)
white_n_slow
Post by white_n_slow »
i've got them on my honda (actually, all my bushings are polyurethane). The endlink bushings really do clean up turn in, but don't expect anything drastic.
As for sound, I slopped axle grease all over the bad-boys, and haven't heard a peep yet.
non legacy owner.
