SHE'S BACK!!!!!!!!!!!!!!
Posted: Sat Oct 30, 2004 8:40 pm
by LegacyPunk
Take that code 22 you POS!!!, I got you bwahahahaha. So here'e what went down...
1 Legacy + IC + code 22= :cry:
1 Legacy - IC= - code 22 = :D
So it was as I feared my IC was causing my code 22 and my air leak noise, Im deaming my IC setup unstable so its back to stock. Running 9-10 lbs of boost is safe without an IC correct? I started her up and the CEL didn't come on at all.
Im Sooo relieved and happy that she's back to her spirited old self :D :D :D
Posted: Sat Oct 30, 2004 8:50 pm
by Subaru_Nation555
9 or 10psi of boost of probaly fine since stock is 8.7. I am still weary of adding an intercooler for those reasons.
nice equations by the way
Posted: Sat Oct 30, 2004 9:21 pm
I don't see how removing the intercooler could fix a knock sensor trouble code... It might be masking it by removing some vibration, but you'll still probably get the code eventually.
9 to 10 psi should be okay with an upgraded exhaust, which your sig indicates you have.
Posted: Sat Oct 30, 2004 11:18 pm
by LegacyPunk
I don't know either. It might of been because the turbo to Y-pipe pipe was kinda kinked and could of really limited air intake, also the IC was vibrating a lot when I came to stops. Ill balme it on MFS :wink:
Posted: Tue Nov 02, 2004 2:54 pm
by LegacyPunk
Well, as always, vrg3 is right. Code 22 on the next day :( and then I get to school today and it goes off. I definetly think its just my faulty re-wairing of the knock sensor. At least I figured out that my IC setup had an air leak somewhere.
Posted: Tue Nov 02, 2004 3:48 pm
Sorry. :(
Posted: Tue Nov 02, 2004 6:11 pm
by LegacyPunk
Ill get it fixed someday soon, I hope. I think since it goes on and off intermitently that my knock sensor (fairly new) is still good and its all because i dont have a shielded wire or whatever. :roll:
