Fuel cut.. how do i get around it??
Posted: Mon Aug 25, 2003 6:28 pm
i have a uk 2lt turbo.
De snork and panel filter
Turbo back twin dump exhaust (noisy but i love the backfires lol)
Forge motorsport dump valve
ekotek valve
wrx cylinder heads
High pressure oil pump
Pi lowered springs
16in WRX alloys
MBC set to 13 psi
Boost gauge
water/air intercooler as standard
question... what do i need to do to prevent fuel cut off if i increase boost more, i run 97 ron fuel will i need to change timing/fueling or can i just get round cut off and increase psi a little. answers and comment pls as more boost required , but not at the risk of blowing it.
Engine runs rich at the moment so i think fueling will be ok for a little more just the cut off doing my nut in.
tnx
Crash.
ekotek valve
wrx cylinder heads
Pi lowered springs
16in WRX alloys
MBC set to 13 psi
Boost gauge
tnx
Crash.
