Small FMIC in TMIC location???
Front, Top, Air, Water.
magicmike
Post by magicmike »
I'm thinking of doing a small FMIC in place of the TMIC and having it stick straight up through the hood. Like 80 % of it or something. I'd have to mod the hood pretty heavilly of course. Has anyone ever thought of this or is it just plain stupid? What are you thoughts???
Mike
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
legacy92ej22t
Post by legacy92ej22t »
I don't know sounds a little wierd to me. How are you going to protect the i/c? 1st time something hits the i/c at speed( like a bug or stone) it will get damaged. I think a small fmic as a tmic is ok as long as you can pipe it in but instead of having it stick up out of the hood have it lay normal and just fab a better hood scoop. My 2 ct. :)
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Brat4by4
Stratified
Post by Brat4by4 »
That's what mesh is for, and it's much less likely to get hit by something than a true front mount. It would look pretty trick (maybe just different), and I think that would probably reduce pre-heating.
ciper
Post by ciper »
Put a "brim" on the cooler, otherwise air will just go around it! Angle it forward a few degrees as well, this will create higher pressure near the bottom.
legacy92ej22t
Brat4by4 wrote:That's what mesh is for, and it's much less likely to get hit by something than a true front mount. .
You're right, that is what mesh is for but when you use mesh on your hood scoop or bumper hole there's space between the i/c and mesh. If the i/c is sticking up out of the hood, unless you fab some kind of spacer for the mesh it would be useless except for maybe smaller insects. If you wrap the i/c in mesh and a stone hits it you're still screwed unless there's a space to absorb the impact. I'm sure it could be done though and it would be very original.
What about a big scoop, like the sti or maybe something custom, then put the i/c in at a steep angle so it's up in the scoop above hood level and use mesh on the scoop opening? I think that'd look pretty sweet and very custom IMHO.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
FrmRgz2Rchz
Post by FrmRgz2Rchz »
That might look kind of funny, but it does give me an idea. I'm wondering if I could make a temporary setup just like that for track days. It's a wicked idea, I'll give you that.
Andy Rose
1993 Subaru Legacy Sport Sedan
2003 Subaru Impreza WRX
2004 Subaru Impreza WRX STI
1999 Hyundai Accent
