The rearend.. and discouragement
Posted: Wed Nov 24, 2004 2:57 pm
by bignose
So, still working on extracting parts from my donar L wagon, to put a manual into my turbo wagon..
Last to come out is the rear end, i have the axles out of the knuckles, all of the skid plates out of the way etc, I'm just wondering, what in the hell does the rear end hang from ? It was getting dark when i reached that point last night.. so I'm sure i can figure it out, but i just figured i'd ask.
this project i'll admit is getting a tad bit discouraging, the clutch from teh donar is shot, the springs have sides ground down. So i think i'm likly gonna go with teh wrx clutch/pp/flywheel route.. but to boot the tranny sounds like it has shit in bad shape inside, and when i bought hte car they said the rear end might be shot ... oh well. car was 150$can, hopefully things will work.
the way i see it, once i do the swap, from auto to manual, ripping out a rear end to put in a new one should be childs play, likewise with a new tranny etc, "once all the work is done"
jeff.
Posted: Wed Nov 24, 2004 3:45 pm
The rear diff is held up by the front carrier subframe. Four bolts attach the diff to this piece, and the rear diff mount.
Your best bet is to put a jack under the diff, unbolt the front subframe, loosen the two rear bolts that hold the rear diff mount to the rear subframe, and lower the entire thing as one piece.
Check out some of the pictures from my swap project and you'll see what I mean
http://www.surrealmirage.com/subaru/swap/pictures.html
Also....which transmission are you planning to use? The one out of the L? If so, you will not be able to use the WRX clutch/pp/flywheel.
Posted: Wed Nov 24, 2004 3:51 pm
by bignose
http://www.surrealmirage.com/subaru/ima ... P_3041.JPG
is that the image you mean with those 4 bolts ? i took them out and the other for that are parallell to the ground.
why can't i use the clutch/pp/fwheel on the L tranny ? is it alot different from the turbo one ?
am i making a bad choice all together putting the tranny from an l wagon onto a turbo wagon ?
Posted: Wed Nov 24, 2004 4:54 pm
by THAWA
ooooooo bignose, what year is your touring wagon? If it's a 93 or 94, can you take pictures of the subframe? The underside mainly where the lateral links attach to the subframe?
Posted: Wed Nov 24, 2004 4:56 pm
by bignose
my touring wagon is a 94.. unfortunatly i'm 200km's away from it. it's in storage in the grandparents garage.
Posted: Wed Nov 24, 2004 4:57 pm
by THAWA
grah, what year is the wagon you're taking the rear off of? If it's a 93 or 94 could you do the same thing? :)
Posted: Wed Nov 24, 2004 4:59 pm
by bignose
it's a 92.. i think. ;)
Posted: Wed Nov 24, 2004 5:03 pm
by THAWA
hmm, are there endlinks or droplinks?
Posted: Wed Nov 24, 2004 6:02 pm
by bignose
i'm not sure.. [i'm not good with the lingo] but if you are looking to buy them, all i can say is you don't wann them as i cut all that shit out with an angle grinder ;)
