instead of swapping over new lateral links and using crappy drop links, i converted it over to the GC/WRX style "C" style endlinks. i welded on 4 "tabs" to the NA lateral links, and positioned them appropriately.
it's not the best pic, but you get the idea:
(link if pic doesn't work -> click)
the OEM plastic C links are pretty flexy, and it would be a good idea if you do this mod to upgrade them to something like this:
or if you want, pick up a set of adjustable endlinks to change preloading
but for now, it's working great. it was well worth it for the $100 i spent on everything
