Am I seeing it correctly, it looks like a triangle? Do you think it'll fit under the hood? Or maybe with the right scoop it would sit up in it. It's hard to tell
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
I know for sure that the core is a perfect rectangle. The tanks are the same size at the mount. The odd shaped parts are the tank ends.
If this helps, the portion you see in the images will actually be closest to the transmission (each picture is the bottom of the cooler if we used it)
The "lower" tank in the image will be on the drivers side as the outlet while the "upper" tank will be on the passenger side as the inlet. The "bars" on the core will run perpendicular to the vehicles direction of travel.
The intercooler will sit exactly in the middle of the space between the strut towers, not off center like the saab unit.
I have been contemplating getting one of these saab ic's for a week now. What is the maximum boost possible withone of these units? I know someone already has one of these on.
Mike
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
magicmike wrote:I have been contemplating getting one of these saab ic's for a week now. What is the maximum boost possible withone of these units? I know someone already has one of these on.
Mike
The Miata crowd has been using this IC with real good results for quite some time. You should have no problems with it.
My over all plan calls for 20 lbs of boost (with all the other proper stuff that is required to get there of course) I was planning on a FMIC but I need something in there so I can at leaste be pushing 12lbs or around there. up to 15 lbs would be very nice. Basically, if this IC can get me well enough to where fuel cut is I should be ok. After that I'll upgrade to a FMIC when I do my injectors and fuel pump and piggyback a/f comp.
Mike
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Honestly guys Im just trying to help out. I have no plan to use an Air to Air unit or I would have bought one of them already. Im hell bent on a good air to water system.
I picked up an 85/86 ish thunderbird TMIC for 25 bucks! I dont know if it will even fit but its all they had. All the late model saabs there had already been raped. The guy told me that some kid has been going there and taking every one he can find. Can you say ebay?
Mike
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
I bought a tbird intercooler off ebay a while back. It was an 87 one I think. It was too big. Barely though.
-Ryan
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
YUK! don't bother, although I suppose it is better than none at all.
magicmike, you have a 87-88 t-bird IC. They are a good TMIC, if you can get enough air through your hood it will work fine. My brother has an 88 T-bird and 20psi through it, 280hp 2.3L
And you do plan on a new turbo right???
I am loving my Liberty Air-Water IC and would recomend it.
I already have a brand new VF34 that cost me a pretty pennie. Its about 80% installed. I'm working on getting it in there as the compressor side is HUGE. When I have it in I will post what I did and photos. In the mean while you can see some pics of the engine rebuild in progress that I posted earlier.
