EJ20 Rocker cover torque settings
dimistyle
Post by dimistyle »
Does anyone have a scanned copy of the torque setting for the EJ20 motor, I am going to attempt to replace the leaking gaskets on the rocker covers and would like this info before I make a start.
I know I need 2 rocker gaskets, 6 (?) O rings seals for the bolts and I guess a couple of O rings or gaskets for the oil inlets on one of the rocker covers.
Anything else I need to buy. Other than a Haynes manual?
Cheers
'92 Sub Legacy VZ Wagon - away we go!
mikec
Post by mikec »
If its the same as the EJ22, the FSM torque spec is 3.6 lbs. But if I remember right, they bottom out around that same time.
dimistyle
Post by dimistyle »
Thanks, I take it the EJ22 is a twin cam aswell then it will be the same, all the doc's I have read are for single cam. So I was not to sure. :)
