first i did the turnsignals
Before:
After:
side by side comparison:
how i wanted to put them back, but couldnt because they would be blinky orange foglights
how they went back in:
that last picture was with 3M headlight protector stuff on them to prevent the before pics from coming back to life.
Then i did the headlights:
no before pictures but after:
Procedures:
1. buy waterproof 600, and waterproof 1,500 grit sand paper, borrow buffer + buffing compound, and meguires wax. 3M proctectant film if so desired.
2. fill a bucket up with water and place a piece of both aformention sand paper in it and let soak for a couple minutes.
3. Start sanding with the 600 grit until smooth and the "water dust" coming off is clear
4. Sand with 1,500 grit untill it is completely smooth and there is no pits/ imperfections
5. pour buffing compound of choice on and buff until nice and clear.
6a. you can put meguires wax on the head light and let dry. wipe off wax
6b. or you can cut and place some 3M clear protectant film over the headlights/turnsignals ( i put them on the turnsignals, not the headlights)
7. enjoy being able to see at night.
