New Style WRX Lower H Brace
Do these fit? I assume they do as the chassis points haven't changed, but I want to confirm that this is true.
Post by BAC5.2 »
I was curious about this too.
None of the front suspension of the GD bolts up (except strut tops, and only the stock and Group N mounts, not Camber plates).
I think they changed it, unfortunately, because the GC Cusco and STi H-Braces are rare. Hard to find for a decent price, and I've yet to see one on e-bay.
HOWEVER, teagues has the Cusco rear subframe support bracket for 50 bucks for the GC. That should fit no problem.
THAWA
Post by THAWA »
2nd gen have different control arm mounts at the crossmember/subframe, the lower arm bars are different to accomodate this.
The tophats and struts fit from a 2nd gen.
The rear lower arm bar will most likely not fit. Reason being you have no where to mount it and no reason to honestly. There are at least two different rear crossmember designs, one like at least the 90-92 with the dogbone style of mount that mounts the rear diff to the crossmember, and another style where the diff mounts to the crossmember directly. The second type will accomodate the rear lower arm bar. The first type will not. Can someone confirm which type 93-94's have. I'm assuming the first type but you never know.
dscoobydoo
Post by dscoobydoo »
I picked up the GC8 one (front lower brace) and it fits.
Actually found it on ebay for $75
I am sure the GDA one does not fit, as comparing the two, the mount points are a bit off.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
