I was prett bored tonight and got to thinking.
questions
-how similar is a legacy air srut to a conventional airbag strut?
-are all the original equipment ones so shot that they wouldnt be worth using?
-how much tavel do the air struts provide?
-how adjustable is the factory setup(complete)?
-what dampers are available for the air struts?
I always hear people saying how crappy the air suspension is due to leaks and such.
things needed:
I'm thinking that much of the system can be DIY. airtank and compressor certainly, JY air struts,(take a bike pump with an adapter to test them?) valves may have to be from a supplier.
-on board air compressor using stock compressor or A/C compressor(many how-to's for this online, could be done DIY for cheap)
-air tank: stock in fender or diy in the trunk
-valves/switches(???) not too familiar with how these are set up in lowriders
-lines to air struts
according to www.car-part.com air struts go for about $200-$50 each. new prices are sure to be exorbitant, didnt even check that.
I figure the best way to set up the camber for these would be with 0 deg. at whatever the normal ride height would be, (1"-2" below stock??) lifted it would have slight positive camber(outer edge of tire digs a little for better traction in the dirt? ASSuming
I would be willing to try and rig something up if I were to come across a set of good air struts/ parts for cheap. anyone wanna donate to the cause?
feel free to flame, laugh, contribute ideas, ask more questions, etc. Ive never seen the air struts in person so maybe this concept is totally flawed/a big headache waiting to happen. just thinking out loud is all. discuss.
