Bog/Jerking...No check engine light
TurboSubie
On the legacy turbo, when you hit about 3500 rpms it starts to jerk and buck( I feel like im riding a bull) also the car just doesn't have any umphh(get up and go) the motor seems strong and doesn't burn any oil...any ideas...help is appreciated
1994 Aegian Blue Subaru Legacy Sport Sedan. Mean Muggin.
1995 Honda CBR 600 F3 D&D complete system,K&N, few other things..
TurboSubie
The car is all stock, I just got it running a few days ago from a MAJOR electrical malfunction. Im not sure im hitting the fuel cut if the car is all stock...maybe if I was running more boost. I did try adjusting the TPS(throttle sensor). If this was even slightly off would it cause this problem?
TurboSubie
it almost seems like I am not getting enough fuel, I am going to check the pressue at the fuel filter and at the regulator to see where the problem may be. would I need aMBC if I am running stock boost? BTW how much is stock boost.
