EJ22T Valve sizes
EJ22T Valve sizes
I haven't been able to find these anywhere... Anyone know what they are, I'm trying to use Desktop Dyno 2000 but can't find any detailed info anywhere...
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
I have a few manuals at home I'll check for you if I remember....
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
let me know if you find anything.
i've searched the FSM's and couldn't find anything....
Yea Subaru New Zealand!
Hi Mark,
We can supply the valves
13201AA480 nz$28.05 each (Intake)
13202AA490 nz$29.57 each (Exhaust)
Don Fenwick
don@possumbourne.co.nz
edit " oops these are EJ20T Part numbers..
Did you try a dealer? they seem to be almost the only ones with them except: http://www.sivalves.com/subaru_valves.html but I dont know if they have turbo valves.
Mark
Hi Mark,
Don Fenwick
Mark
It's much harder then it seems to find this info......trust me.....I've got FSM's and they don't tell you squat.
Short of measuring them yourself.....not really sure what else to tell you.
Hey,
I was looking through my chiltons manual last night. I did see some valve related info. But it was only showing the ej22 heads, and I swear I've seen that the ej22t heads had different valves in the other manual that I have. At the moment my machinest has that manual so I'll double check when I get it back. Just out of curiousoty, what specs are you looking for exactly? I'm assuming all of them, but a list would be helpfull.
Mike
Mike
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
I believe he's looking for the size of the valve head, its diameter.
yes.. exactly, also if you can find any cam related info(lift, valve opening and closings, etc..)Legacy777 wrote:I believe he's looking for the size of the valve head, its diameter.
Check out this thread viewtopic.php?t=269
Also check out the link in the thread
And this one too http://forums.nasioc.com/forums/showthr ... did=292519
I put numbers in there for the N/A.
I can try and find info on the turbo.
Here's the info for the turbo
Here is the info I have for the EJ22T. It's all coming straight out of the 92 FSM.
Cam width: 28mm
Cam height: 32.286-32.386mm
So that would give you a max lift of 4.286-4.386mm
It doesn't directly give you duration, however it gives timing on the intake & exhaust valves individually
Intake Valve Timing:
Opening: 6 degrees BTDC
Closing: 52 degrees ABDC
Exhaust Valve Timing:
Opening: 42 degrees BBDC
Closing: 10 degrees ATDC
So....from those numbers we can say the following.
Intake valve duration: 238 degrees
Exhaust valve duration: 232 degrees
NOTE: I've found errors before in the FSM.......so do not take this info as absolute, but merely as reference.
Cam width: 28mm
