Hi,
I am trying to decide which would be the most useable torque wrench range for a Legacy. Being a bit short on cash I was wondering where to start i.e. which is the range you use most.
Any advise regarding producers welcome as well.
Thanks and best regards
Dusan
Torque wrench question
- Spelling Nazi
I had a craftsman digitork 3/8 wrench that works more than fine. I've used it on my suspension installs, and it seems to go high enough, i believe the max torque setting is 80 ft lbs. Only problem with the craftsman products is that you only have a 90 day warranty on the torque wrenches, but they do offer calibration, and it's a hell of a lot easier than tracking down a snap-on or matco truckYukonart wrote:Be sure to get a 1/2" drive . . .they're longer and are easier to use. Something that at least goes from 50-100 ft/lbs should be the most useful. . . considering wheel lugs, suspension bolts, etc.
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
As with most other things, the digital version isn't as accurate as the mechanical version. Though even those aren't completely accurate depending on which you get. Get a clicky style definately.
I like the clicky styles too. Makes things very definite and intuitive.
Speaking of torque wrenches, I need to go buy one. I think I've lost mine.
- Spelling Nazi
the digitork is the clicky version. It merely shows you the exact torque numbers that you have it set upon.
http://www.sears.com/sr/javasr/product. ... pt#tablink
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW
