Alright, so I will be doing the swap very soon and thought maybe someone could remind me if I'm forgetting anything I might need.
I have:
Group N tranny and engine mounts already. I'm trying to source a new clutch and maybe a wrx flywheel so that I can switch to a WRX clutch. The motor has a new water pump and timing belt already supposedly so I don't need that.
Is there anything else I should definitely address before i put the motor in? Any comments or suggestions would be great.
I'm excited, Subarina will be back bigger and badder then ever. She's also getting GR2's on all 4 corners with Tein springs and Group N top mounts. I'm also putting on an aftermarket steering wheel. Hehehe
I'm also going to do a full tear down and rebuild of my original motor. Probably do either a head swap or rebuild the SOHC's to there max potential.
Special thanks to Vikash and Phil for all the support and hard work!
Wooohooo!!
