Head Gasket
Head Gasket
I am just about to buy a 92 Legacy Turbo, and it has a blow head gasket. im just wonering what other gaskets and seals i have to replace??? It has 185000 on her. And im also not sure what side its on... Is there anything really important i should replace?
92' Legacy Turbo (EJ22T)
As long as you have everything taken apart, you should replace both sides.
Along with the head gaskets, the job shouldn't be done without replacing the following:
Exhaust Gaskets
Intake Manifold Gaskets
You should also change the water pump and gasket, thermostat and gasket, and timing belt. This would also be a good time to replace the cam seals and o-rings, along with the front crank seal. The valve cover gasket and valve cover bolt grommets would be easy to do at this time too.
I'm sure I forgot something seeing as its early in the morning, I just got up, and I dont have much time to think of everything.
I also went a bit farther and rebuilt my heads, which may be a good idea for an engine with 185,000 miles on it, but itsn't absolutely necessary.
Andrew
Exhaust Gaskets
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
