'95 rear tophats
'95 rear tophats
will '93 rear tophats bolt into a '95, or did the bolt spacing change by then?
Only bolt difference is the 02+ Impreza. The rears are different, and the front orientation is different (but spacing the same). WRX camber plates will NOT work in a Legacy or GC even, unless they are noltec plates.
Rear strut length difference?
I'm not sure. Check KYB's website, and see if there are part number differences.
