Perf. springs & struts for 92 legacy wagon
Posted: Wed Jan 26, 2005 7:20 pm
by ryno50485
I have a 92 wagon and i need new struts BAD!! Would wrx struts and springs work? What type of performance struts and/or springs could i get that aren't going to break my wallet?
Posted: Wed Jan 26, 2005 7:32 pm
by 91White-T
Look 5 threads down.
Posted: Fri Feb 11, 2005 7:14 am
by LaureltheQueen
search button.
I wouldnt suggest wrx stuff for the car unless it's coilovers just because it's a wagon... There's weight distribution that you need to think of
Posted: Mon Feb 14, 2005 12:12 am
by ryno50485
I actually just bought a full suspension off of a 02 wrx wagon with tein springs. I found out that no modification is needed and it will fit fine. I'll let you know how it turns out.
Posted: Mon Feb 14, 2005 10:38 pm
by LaureltheQueen
i'm projecting ass-dragging
Posted: Mon Feb 14, 2005 11:07 pm
by ryno50485
how so?
Posted: Mon Feb 14, 2005 11:27 pm
by jamal
depends on the rear spring rate. Weight distribution is much more front-biased on the BF than the GG. The rear spring rate on the teins is still higher than stock, though. It's just that the fronts are even more so, so they will settle less than the rears under the weight of the car.
Posted: Mon Feb 14, 2005 11:29 pm
by LaureltheQueen
the ass of the leg wagon is heavier than the ass of the impreza, if the springs are built to support a wrx back end, then they'll likely sag more with a heavier load on them
Posted: Mon Feb 14, 2005 11:37 pm
by ryno50485
what do you recommend since i already bought them? Do you think it will be a problem?
Posted: Mon Feb 14, 2005 11:48 pm
by jamal
I don't have the link to that suspension chart on nasioc, but if you compare the tein to the stock wagon, you'll be able to tell how the suspension will be uneven. Also, it's my understanding that you will need new rear strut tops for the wrx stuff to fit your car.
Oh, here it is
BF springs have a higher rate in the rear, WRX wagon springs have a higher rate in the front. That's not going to be good.
Are the springs the same length? They're shorter in the front, I think. If they're the same, you could put the rear springs in the front struts and the front springs in the rear, maybe.
Posted: Mon Feb 14, 2005 11:55 pm
by LaureltheQueen
Personally, I wouldn't have done it, you could try to re-sell them and order whitelines, or get a set of cheap-o coilover sleeves and put them over a set of agxs. If you truly want good performance, it's going to cost you. Suspension is tough on the wagons because they do have such a heavy rear end. Try using the search button or reading a few threads down
http://bbs.legacycentral.org/viewtopic.php?t=17509
Posted: Tue Feb 15, 2005 12:12 am
by ryno50485
Yeah i have rear top-hats that are coming with the suspension. I think i'll just try it and see how it turns out. I know they will fit but i'll have to wait and see how the weight distrubution works out.
Posted: Tue Feb 15, 2005 12:17 am
by jamal
Spring rates:
BF: 134F 190R
WRX wagon H-tech: 196F 140R
WRX wagon S-tech: 218F 157R
Posted: Tue Feb 15, 2005 7:42 am
by LaureltheQueen
PLEASE post photos when you get this swap done
Posted: Thu Feb 17, 2005 12:17 am
by MY92
jamal: are those rates for GC/GF impreza or the bug eye one?
I would've though that any bug eye suspension would be ok because it is of similar weight to our BC/BF's.
Posted: Thu Feb 17, 2005 12:39 am
by jamal
Posted: Thu Feb 17, 2005 4:44 pm
The bugeye is more nose-heavy than our cars though.
Posted: Thu Feb 17, 2005 5:48 pm
by ryno50485
I checked up on the weight of an 02 wrx wagon compared to the weight of my 92 n/a wagon and they are within 100-150lbs of one another as far as curb weight goes. The front weight and the rear weight are very close as well. I don't believe it will be a problem, but i will post pictures of the process when i am done with the swap.
Posted: Mon Feb 28, 2005 12:27 am
by ryno50485
Hey guys I finally got the suspension swap done!! I posted a new picture in the picture gallery. I'll post more pics soon!! CHECK IT OUT!!!
heres the link
http://www.bbs.legacycentral.org/viewtopic.php?t=20294
