The other day I was fueling up my newly repaired turbo and after I was done I got in to start it and nothing. The headlights were on etc. but it wasn't turning. I know it's the starter so I open the hood and do the Fonzarelli thing (percussive blows to the starter housing) and it started right up.
Now, my question(s) are (I'm at work right now and I can't look up details about the starter) how is the starters on our cars constructed? Is it a solenoid type? Is there a mechanical actuator in there or was it just coincidence that it started after I struck it? These may be dumb questions and I apologize for my ignorance in advance.
Starter troubles
Starter troubles
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
There's a solenoid that simultaneously moves the pinion gear out (so it meshes with the teeth on the flywheel or flex plate) and closes the high-current contacts to spin the motor.
Tapping a starter with a hammer is a well-proven way to make a dying starter work when it otherwise won't. If you think about most of the ways a starter can fail (tiny breaks in the solenoid or motor coil, worn solenoid contacts, worn motor brushes), it kind of makes sense that percussion could mask the problem.
Hybrids are different - combined with the alternator/flywheel. Citroen or somebody had also done the starter/alternator combo decades ago.
Look at the last thread. I added the link where to order the contacts.
http://bbs.legacycentral.org/viewtopic. ... sc&start=0
You could probably just give your local toyota dealer the following part # 28226-72010 and 28226-72080 and get them. Not sure what costs would be
