snorkus...get rid of it or leave it where it is?
Wouter1973
Hi! I'm from The Netherlands, I drive a Sub Legacy 2.0 GL. Completely stock, except for the wheels. On this forum I read a lot about removal of the snorkus thing, and the general idea on this forum was 'get rid of it'. However, on the DutchSubaru forum I read that it's not a good idea to remove the snorkus, because the airfilter would suck moist air without the snorkus, there would be a danger of damaging the engine that way. So...what should I do? I have to admit that I wouldn't complain if I'd hear a bit more of the boxer-sound when I drive...
And suppose I decide to remove the snorkus: should I remove the side-panel on the passengers-side to be able to remove it?
legacy92ej22t
I'd remove it. If you're planning on doing any creek crossings I would leave it in though.
Remove the passenger wheel well liner to get access. Then it's just a couple bolts. If you want to hear what it will sound like without completely removing it at first you can undo the bolt that holds it to the air box and then push the snorkus back into the fender and to the side. If you decide you like it then you can remove it completely.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Or just hack it apart. Open the box up after removing it and remove the pipe that connects to your airfilter. Then rebolt that pipe to the airbox. That way you don't suck in hot engine air (less horsepower). And don't worry about sucking in moist air, it is actually good for the engine. It helps prevent detonation. They actually have water injections systems on cars to help stabilize high horsepower applications. And what do you think happens when you drive down the highway in the rain?
Wouter1973
Ok, did it! Cut mine at the bottom of the U, and put it back in, without the resonance box around the pipe. I guess the airflow should be a bit better now. Resetted the computer and went for a drive. I didn't notice any change of sound or increase of power or something..in fact, I didn't notice any difference at all! I think I'll leave it this way, because theoratically the airflow should be much better this way.
Nomake Wan
It is removing restriction from the intake system, and with a high-flow drop-in filter in the airbox, there's little restriction left. I've noticed a slight increase in torque (as per the chirping tires that didn't chirp before) as well as a very slight overall power increase. I'd guess about 5hp increase, tops. But since I didn't dyno my car before the mods, I have no way of knowing how much it really increased.
[url=http://www.cardomain.com/ride/762395]1990 Legacy L (Sold)[/url]
[url=http://www.cardomain.com/ride/2564067]1992 SVX LS-L[/url]
[quote="LaureltheQueen"]I like my automatic, it's fun to drink coffee and smoke civics at the same time[/quote]
Wouter1973
I wouldn't worry about water or anything. After I hit a deer last fall, I've had no plastic fender liners so the airbox hole is open to the fender. The fender has been filled up with snow, hit with lots of water and whatever else I've driven through. I've put on about 40k miles with it like that, and have only needed to clean my K&N once.
I just yanked my out today. I cut the U, then I removed the blank (fog light?) from under bumper and cut off the back so now it will be my air intake bezel. Tomorrow I'll pick up some flex duct and connect the intake tube to the bezel and deal w/ the bezel attachment.
Goodbye my sweet, parting is such sweet sorrow....1993 BC6 , Saab IC, with xtras Hallman MBC, HKS FCD , wrx exaust.
Send some pictures when you are done... I am curious abolut the result!kidwired wrote:I just yanked my out today. I cut the U, then I removed the blank (fog light?) from under bumper and cut off the back so now it will be my air intake bezel. Tomorrow I'll pick up some flex duct and connect the intake tube to the bezel and deal w/ the bezel attachment.
Good luck!
1998 Legacy GL - EJ20 SOHC !!
indeed! let us know how it works, I was considering using the Foglight blanks (with some plastic hosing) as air inlets for a break cooling system, but this might be a better idea. (would see better use on a day to day bassis than break cooling ducts)
tris91ricer
- Title Whore
maybe...
I'm not too concerned about the mesh, right there air is going to be hitting it pretty hard.
The corrogated tube is the issue I think, it's all I could find to get it done. I was at the shops at the race track today and noticed a similar setup but they had a much smoother (and more durable) looking flex tube. Gotta find out where to get some. Maybe I'll just go dumpster diving lol
Hm... After I took mine off the engine now screams at full throttle!Wouter1973 wrote:I didn't notice any change of sound or increase of power or something..in fact, I didn't notice any difference at all!
kidwired You might want to put some tension on that "waste" line to lower restriction. Also a velocity funnel can be useful, but then it won't match your nice bumper setup.
Did you double-check your math? Cuz I come up with something closer to 90 mph:
A 2.5 liter four-stroke engine consumes 1.25 liters of air per revolution.
At 6000 RPM, this is 7500 liters per minute or about 27500000 cubic inches per hour.
2.5 inch pipe has a cross-sectional area of about 5 square inches.
So air would be going through a 2.5" pipe at about 27500000/5 = 5500000
inches per hour, or about 87 miles per hour.
Did I get that right?
