Seriously. I was thinking of jerry-rigging one up from home depot. If I manage it, I'll put up a list and whatnot.
I started thinking about this when I noticed some oil blowby coming out of the turbo->TB elbow. I figured it would be a good idea if it could be done for cheap, as I couldn't see spending $100+ on one.
Where would a catch-can go?
IronMonkeyL255
Rio Red '91 Legacy SS
IronMonkeyL255
dscoobydoo
OK, is it just me, but after all that discussion, we came to the conclusion that there was nowhere good to install a catch-can? ( Due to the way the PCV system works)
Or am I missing something??
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
Yeah, there was no very clear answer.
There's my suggestion -- putting it between the F-pipe and the breather on the top of the block. It'd be kind of hard because there isn't much room, and the can would need to have 3/4" fittings.
And there's Steve's suggestion -- putting it in the 12mm hose between the F-pipe and the compressor inlet. It'd be kind of hard because there isn't much room, and the can and whatever hose you add has to be very low-restriction.
