white smoke
bluesubaru
white smoke
Hello again,
My problem or worry is this...
Whenever i begin to hit boost and let off the gas, not a huge amount of white smoke comes out, but a noticeable amount does. I have notivced it to only happen when I blow off (atmospheric) or push the car harder than normal. But when cruising, no smoke at all.
I do plan on going reciric, as soon as my ordered intake plumbing comes in. But I am hoping its not what I think it is....
I have read posts on here and nasioc.com about others with similar problems, leaking coolant, burnt oil, fuel, etc. Would this be my problem too?
Any ideas or suggestions?
95 Legacy N/A EJ22 - Turbo @ 5.5psi
WRX Turbo and Intercooler
STI Exhaust
STI Exhaust
IronMonkeyL255
It may be that it's running rich for a split second when it vents. The ECU sees how much air is coming in, but when you vent some of it to atmosphere, it thinks it has to fuel for more air than is there.
Does that make any sense? Somebody please correct me if I'm wrong.....
Several people on here have noticed this phenomenon. I believe BAC5.2 was atmo for a while, but went back to recirc because of this.
Rio Red '91 Legacy SS
bluesubaru
I thought it was that too. That the engine dumps fuel for air that isnt there anymore. Which is why recirc. is the best thing to do overall. Even if I have the greddy emanage and I can do it still, my car doesnt seem to agree.
Anybody else confirm this?
STI Exhaust
STI Exhaust
No, I am still atmospheric, with no issues like that.
White = coolant.
Blue = oil.
Black = fuel.
White = coolant.
Blue = oil.
Black = fuel.
bluesubaru
bluesubaru
Oh yea, that's right. Yea, your running 9.5:1.
I wonder if the EJ22T headgasket would bolt up. It should be thicker than your stock headgasket.
I don't know if headgaskets are like exhaust gaskets, but you might be able to double one up.
bluesubaru
bluesubaru
White smoke is coolant. So I don't think anything you tune will fix a blown headgasket.
bluesubaru
