in all the pics i see of the saab IC and the WRX ones what did you all do about the clutch fluid res.?
they all seem to cover it up. do you have to take the IC off to change the fluid?
what about the clutch fluid resevoir?
greg donovan
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
IronMonkeyL255
Supposedly. Mine is a slushbox, so I don't have to worry about that......
I remember someone mentioning that they just put a piece of padding on the resevoir and laid the i/c on it.
Rio Red '91 Legacy SS
Depending how your particular setup is laid out, the intercooler might or might not rest on the clutch fluid reservoir. My Saab intercooler doesn't touch it. But, yes, it does still cover it up so you have to remove the intercooler to service the clutch fluid.
greg donovan
hmmm, that is not what i wanted to hear. i know it isnt changed that often but i have little interest in turning a easy job into a hard one.vrg3 wrote:Depending how your particular setup is laid out, the intercooler might or might not rest on the clutch fluid reservoir. My Saab intercooler doesn't touch it. But, yes, it does still cover it up so you have to remove the intercooler to service the clutch fluid.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
greg donovan
NuwanD
My wrx i/c sits just above the clutch reservoir making it in-accessible with the i/c installed. You can still easily see the level of the fluid however. Tranny fluid changes are made easier if the intercooler is removed as well.
I can remove my intercooler within a matter of minutes (although the strut tower brace slows things up a bit), re-installing is a reverse process that doesn't take any longer.
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
2000 Impreza 2.5RSC (Supercharged)
1990 Rover Mini 1000
2004 Forester XT
DeusExMachina
