Sedan vs. wagon rears (struts)
Posted: Tue Feb 08, 2005 4:09 am
by 91White-T
Search turned up that they aren't interchangeable. Why exactly is that, are they phyiscally different, and how so?
edit: struts that is
Posted: Tue Feb 08, 2005 3:53 pm
Are you talking about the same year cars & same drivetrain....or different years?
As long as they are both AWD and from the same range of years 90-91 and 92-94.....you should be able to use them.
The wagon struts will typically have a higher damping rate, but that really won't keep you from running them.
Posted: Tue Feb 08, 2005 9:51 pm
by 91White-T
Thanks, I was actually tryin to figure out if wrx sedan struts will work on a 91 wagon. Basically what I want to know is if the bottom two holes will line up, and if the piston comes up to the same place.
Posted: Tue Feb 08, 2005 10:32 pm
hmmm.....I think they will....I know the top mounts are different in the rear for the wrx sedans, but the shaft on the strut still is threaded the same.
Posted: Tue Feb 08, 2005 10:35 pm
by scottzg
check out the spring rates. physically fitting is a far cry from an improvement.
Posted: Tue Feb 08, 2005 11:01 pm
by 91White-T
I'm not actually using the springs, just the struts with coilover sleeves and stock topmounts. So the strut body should fit?
Posted: Wed Feb 09, 2005 12:33 am
yeah, I don't see why not.
Posted: Wed Feb 09, 2005 1:13 am
by 91White-T
Thats what I assumed too, just wanted to double check. Thanks!
Posted: Wed Feb 09, 2005 4:24 am
by scottzg
I believe the strut body is identical front to rear. If this is the case, you might consider putting the front struts in back and vice versa.
Posted: Wed Feb 09, 2005 4:33 am
by LaureltheQueen
the part # on the agx struts is exactly the same from wagon to sedan
Posted: Wed Feb 09, 2005 3:51 pm
scottzg wrote:I believe the strut body is identical front to rear. If this is the case, you might consider putting the front struts in back and vice versa.
The front and rear strut bodies are different, and are not interchangeable.
Posted: Sun Apr 03, 2005 3:53 am
by The Scooby
so right now i have sedan struts/springs on my 94 wagon. and the rear is saging is that because the springs are for a lighter int he rear sedan? the struts are good, but are the spring rates different?
