Sedan vs. wagon rears (struts)
Search turned up that they aren't interchangeable. Why exactly is that, are they phyiscally different, and how so?
edit: struts that is
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
Are you talking about the same year cars & same drivetrain....or different years?
As long as they are both AWD and from the same range of years 90-91 and 92-94.....you should be able to use them.
The wagon struts will typically have a higher damping rate, but that really won't keep you from running them.
Thanks, I was actually tryin to figure out if wrx sedan struts will work on a 91 wagon. Basically what I want to know is if the bottom two holes will line up, and if the piston comes up to the same place.
hmmm.....I think they will....I know the top mounts are different in the rear for the wrx sedans, but the shaft on the strut still is threaded the same.
yeah, I don't see why not.
- Spelling Nazi
The front and rear strut bodies are different, and are not interchangeable.scottzg wrote:I believe the strut body is identical front to rear. If this is the case, you might consider putting the front struts in back and vice versa.
