before anyone screams search let this be known that this thread is not about problems with the power locks (which has been covered extensively i believe)
just wondering if anyone experiencing the same thing.
as stated above my locks work fine.
i am curious abut a situation that involves a passanger. basically when i open my driver door using the inside handle (while car is locked) it allows me to opne door as usual without unlocking door. well on rare occasions and only when i have passenger it will also unlock the pass side door as well (not the rear doors). as if it knows because the pass door was in use that some one is sitting there and likely needs to be let out as well.
i cannot however reproduce this effect. maybe the pass seat has a sensor in it
anyone have any ideas? perhaps the wiring diagram holds some secrets? or perhaps my car just acting up?
would be nice it always worked like that tho, because i always get out of my car using the handle and not unlocking all the doors, and the passanger sits there baffled by our crazy lock system trying to figure out why they cant get out.
