Was wondering if anyone knows what the rear sway bar diameter is on a 94 Legacy GT wagon? Is it 18mm like the Turbo's? Also, will GC8 Impreza RS struts and springs work on this Legacy, I have an extra set of stock ones I'm thinking of putting on since the wagon has over 200K? Thanks.
-Jon
94 GT Wagon suspension ?'s
GC8 struts and springs should work fine, especially if you are AWD. There may be some issues with the rear tophats.. but switching to the tophats from the GC8 will work resolve that.
You'll prolly get told do do a search real quick
i think you can find quite a bit of info about the spring/strut issues.
MK
MK
1992 BC672 AWD 5MT
