Catalytic Converter Question
Trailblazer
Post by Trailblazer »
Is removing the catalytic converter a good Idea? I dont have emissions where I live so that is not an issue. Will I gain power? What are the pros/cons?
91' Legacy L Wagon w/93' 2.2 motor
http://members.cardomain.com/trailblazer24
I wouldn't bother. If you were turbo charged....that'd be another thing, but for na motors.....they're not hurting anything, assuming they're in good working condition.
free5ty1e
Post by free5ty1e »
Yeah, helps if you have a turbo (as they don't really like or need backpressure) - but with N/A some amount of backpressure is needed, I believe it helps with exhaust velocity...
-Chris
91SS 4EAT stock, 200k mi
Post by BAC5.2 »
Well, backpressure is the enemy of exhaust velocity, and the entire exhaust system. You want as little backpressure as possible, with the greatest velocity as possible.
Don't worry about removing the cat. You won't really gain anything other than some sound. If you want the benefits, you can get a high-flow cat, but I would recomend retaining a cat.
scottzg
Post by scottzg »
T3h exh. \/aLve$ w1ll b3 c00k3d!
Don't bother.
dwreck30
Post by dwreck30 »
But on a turbo car it would not hurt the exhaust valves correct? Would only help right?
- Derek
'06 STi
free5ty1e
Post by free5ty1e »
correct. Turbos love free-flowing exhaust systems. Backpressure gives the turbo something to fight pretty much all the time. It's definately not good for spool-up or maximum flow through the turbine.
So, turbo + cat = quicker to burn turbo
N/A - cat = quicker to burn exhaust valves
-Chris
