BOV question
BOV question
I know this question probably have been raised over and over...i would want toput a blow off valve under the hood but i dont have an intercooler?? would that be alright?? and also what kind of BOV should i get?? any help on this subject would be great cuz i don't know jack about this car yet...(91 SS)
the more you read the more you learn. though it is possible to put one on it will only be minimaly louder than stock. yes you do have a stock valve. the one you will need is a bosh replacement found on ebay. you will also need to recirculate it. to install you will need some heater hose and some clamps. but since your stock one probaly still works dont even think about it
-jason
Jason, I am not sure if he is talking about the stock diverter valve.
I think he is more asking about aftermarket, atmospheric BOV's.
You CAN get one, for sure. I'm running one.
Intercooler or not, it doesn't make a difference. At stock boost, there is no reason to replace the OEM bit unless you want the bling bling of the noise.
Unplug the return hose and point it up towards the hood scoop, when you get sick of it plug it back in! (disclaimer: just kidding dont really do this, it will make the car run like ass)
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
I'm running an atmospheric BOV. With no IC, my friend is running one too. I have an IC.
To run ICless, your going to want to plug the connection that goes from the outlet of your DV to the intake tract. Next, is to take off the stock DV and run a hose from the inlet of the DV to the inlet of your BOV.
Make sure that you have a BOV that stays closed at idle.
98 LGT
greddy.
And as long as you block off the return inlet on boot B, running the stock valve as atmospheric seemed just fine for me while in the transitional period between intercoolers. It kinda sounds like Darth Vader exhaling when ya shift, but it stays closed and I never had any idle problems. I also didn't run very high boost during that period...
-Chris
91SS 4EAT stock, 200k mi
