i tried to get an acces odo installed today at a shop here in town, as i dont really have the time to figure it out myself. I am using the Terratrip universal speedo cable probe that locks around the cable and send the signal. Issue is, it needs a 5v power source and they tried three different 5v sources on the engine today and the car wouldnt run properly or the odo wouldnt get a constant signal, so im guessing we need to find another source for a 5v signal. They tried the ECU and two other places.
Car is a 92 subaru legacy EJ22t turbo with Automatic transmission and needs the sensor to make the signal.
any suggestions as to what areas in the car to tap in to for a 5v supply of power to power the terratrip sensor? or is it not worth the fight and maybe better off to run a resistor that converts a 12v signal down to a 5v signal.
thanks in advance for any help!
shawn
troubles in accessory odo install land, need help!
If it draws low current, you can tap the MAP sensor power supply pin. That'll get you 5 volts.
If it's not very low-current, make a 5-volt power supply out of a 7805 voltage regulator chip from your local electronics supply store (or even Radio Shack). One pin goes to ground, one goes to a +12v source, and the remaining one supplies 5 volts. To smooth things out you probably should put a capacitor between ground and each of the other two pins, but it'll probably work anyway.
