I was able to get a good package deal w/ front crossmember, swaybar, steering rack, full exhaust, turbo fuel pump, full wiring harness, and ecu.
My goal is to someday make 300whp.
Initial plans are to replace these regular maintenace items:
*• cam seals
*• crank seals/rear main seal
*• water pump
*• thermostat
*• oil pump
*• timing belt
• lifters?
*• valve cover gaskets/o-rings
• All critical hoses
** PCV valve
* Air Filter
** Spark Plugs
* Spark plug wires
* O2 sensor
Simple Mods to do from the start:
* TB bypass
* Remove boost limiter
* Boost gauge
* parallel fuel lines
Also going to do a compression test, remove the AC compressor, swap over my new style PS pump and GFB pulley set, and install valve cover breathers. Probably will do the TB bypass mod, and check valve too, probably a boost gauge soon.
Anything else I should do to prep the engine before install? I know i have to be missing something
MK
