Subaru Impreza Turbo suspension on the Legacy...!?
Hi! I recently bought an 1990 Subaru Legacy 1.8 GLX (EJ18 SPI (TBI) engine)
I've read somwhere that Subaru Impreza Turbo shocks and springs (the hole leg) fit the Legacy.
And do i need to replace the wheelhub and brakes too?
But what years of the Impreza fit? Does the Impreza GT MY99 fit? It would be great if i could have
a fast answer =)
Thanks in advance, Regards Gustaf, Sweden.
a fast answer =)
http://bbs.legacycentral.org/viewtopic. ... reza+turbo
don't ask what I meant by drivetrain type, i don't even remember now.
scottzg
This has been covered about a billion times, but here it is again:
the springs are different, the struts are different, and the perches are different. This doesnt matter if you replace the whole spring/strut unit with the impreza one, it bolts into place and the rates are very good. It will slightly lower the car, but quite slight.
The easy way to tell is this: If you need a spring compressor to complete your install, you are probably missing a part. The exception is the top mounts, which are the same.
THANKS ALOT for your answer, I'm sorry if I'm a bit annoying but I just bought my first Subaru and my english is not the best in the world... and as I am a student I cant afford to buy the suspension from the Impreza and find it to be a non fit.
But as I understand the "leftoverparts" after his coiloverswap should be enough. I will post pics of the stuff tonight when I recive the pics from the seller.....
Once again.. thanks alot!!!
I'm pretty sure you'll need the top mounts for at least the rear since the springs are tapered in the Legacy (in the US at least).
They will fit with new rear top mounts. The top mount sits on top of the upper spring perch and bolts to the chassis. You might be able to use your existing front tops. Here are some pictures I took of a Group N rear top for a 93-01 USDM Impreza I will be using to install 2004 STi suspension:
I'd say that's a lot of kms on that suspension. Also makes me wonder If I can change my tops without a spring compressor. How are those spring perches bolted on without tops, or were the tops just taken off and the bolt was put back down on the perch?
peter@functionauto.com
scottzg
When i did my suspension, the rear top mounts themselves looked identical, it was the spring perches that were different. I suspect that "topmounts" is misinformation spread by the web, but i can't confirm that. I shoulda checked in more detail, but i had already bought the sti mounts. The spring perches, which gustav has in the pics, are different though.
Legacy springs cannot be done without a compressor, but any 200+ lb fella can do impreza springs by himself; i know i did.
That sounds like a lot of miles on those struts, i bet they're pretty shot. I paid 200 for struts/springs with 8000km on them. For those, i would spend, ehh, maybe 100. Keep in mind im on a different continent.
My english fails me again... so do I need new topmounts or not? And can i use the front ones? Aprox. what does new topmounts cost?
Actually the suspension had "only" been used 90000km. I misunderstood the seller at first... But 350$+ topmounts might be a bit much, or? Is it worth the money over my stock suspension which is in much better shape when it comes to rust, and front shocks replaced once 1999. ?
The rear top mounts were $110 US for the pair, plus about $7 for shipping. These are STi group N mounts, which are nicer and harder than stock. Stock mounts might be cheaper at a dealership.
Now that I think about it, I can't find any places that list separate rear tops for the 93-01 Impreza, 90-91 Legacy, and 92-94 Legacy.
Actually, at boxer4racing, it says this for the KYB tops:
Over here, that is a high price for suspension with that many kms.
So, to summarize:
Yes it will fit
Yes you can use you old top mounts (we think)
It's a little expensive by US standards.
I guess that settles that. Yes your existing tops will work.KYB Rear Strut Tops for Impreza 93-2001 and Legacy 90-1994.
So, to summarize:
Yes it will fit
Thanks alot once again, as the topmounts should fit, the front too?! I will try to get the price a bit lower... if he lowers it then it should be a quite good buy with some cleaning and painting...
Is the dampers inserts or are they hole perch an oil container with an piston in it? Can i cleen them with high pressure water near the top?
92 Le-Turbo-SS
