This is pissing me off...
J-MoNeY
Post by J-MoNeY »
My car has a low idle miss. I can get out of the car and hear the exhaust go from "babababa da bababab da" something like that. Anyways, the exhaust note changes.
Things I've replaced or cleaned: K&N, all PCV hoses, PCV valve, spark plugs with NKG's(properly gaped), plug wires, coil pack, fuel filter. It just makes me think that the car is off a tooth on timing or something. Help me!
98 LGT
damonmlime
Post by damonmlime »
does the car have any other symptoms? my car has a very rough idle and it has a high rpm sputter/miss/hesitation, i changed the plugs, wires, fuel filter, air filter, and it still runs like crap, no CEL, did that d-check mode thing and that did nothing as well, also reset the ecu, did nothing. :(
J-MoNeY
Post by J-MoNeY »
It really doesn't have any other symptoms. Looks like we are in the same boat, dude. :_(
98 LGT
206er
Post by 206er »
maybe clean out the IAC?
heelhooker
Post by heelhooker »
have you checked compression?
1991 ss 5mt ej20g (sold)
1988 mazda 323 gtx
2005 EVO RS
nsantos23
Post by nsantos23 »
definetelly the idle control valve, that probably give you a bad idle, or if you are having misfiring, try to swap the ignition thingie and coil packs.
Neo
1990 L 2wd 5spd 215K miles
damonmlime
i already swapped out the coil pack, that didn't help, what's the ignition thingie? :lol:
J-MoNeY
Post by J-MoNeY »
heelhooker wrote:have you checked compression?
I haven't. Do I need to?
98 LGT
nsantos23
Post by nsantos23 »
yup try it out, the ignition thing is the ignition box by the fire wall
Neo
