Turbo owners: Read before turning the coolant tank sideways!
In some other threads I've suggested to people installing intercoolers that a neat way to avoid having the intercooler interfere with the coolant filler tank is to remount the tank sideways, using one of the original two mounting holes but with the other hole of the tank.
I did that many months ago, and it seemed good. But occasionally I'd notice some dried coolant around the radiator cap neck. I had removed and installed that cap many, many times, so I figured the rubber gasket built into the cap just wasn't sealing anymore. I'd just wipe it up and refill the overflow tank periodically, and I planned to get a new rad cap.
So a couple days ago I finally put a new cap on, proud of myself for promptly fixing the problem five months after noticing it.
But the problem was still there.
That was worrisome... I started wondering if the tiny bit of overheating that happened each time I broke the tank could have caused damage to a head gasket. So then I dropped by a local shop and asked them to test for exhaust gas in my coolant. It was clean.
I finally figured out what was causing the radiator cap to leak. The tank in its new position was slightly higher than its original position. When the engine rocked on its mounts, the cap would actually bang on the hood hard enough to temporarily unseat the gasket and spray some coolant out.
So... Don't just remount it sideways using the stock mounting point. Until I figure something else out, I've just eliminated the filler tank and am idling longer when I park.
Edit: Changed title to reflect the fact that Matt posted useful info below
I found the fix for this! I remounted/rotated mine in the OEM location using the stock mounting points and it actually sits about 1-2" lower then OEM!
What I did was, take the smaller of the two mounting points on the tank and press out the metal sleeve that the bolt runs through. This will allow you to be able to get the larger bolt through the hole. I then mounted it to the larger attachment point. This points the coolant nipples towards the driverside strut tower. It sits slightly lower and there is no pressure on the nipples! You will have to rerun all the coolant lines except the one off the cap, it still reaches. I'll try and get some pics up soon.
Actually, it's such a good fix, maybe I should write up a DIY and it should be a sticky.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Yeah I'd like to see pics Matt
Ya, yours are mounted in a different location OEM too.
I'll try and get some pics up tonight.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
That is a LHD car though.....
OK, here's a couple of pics.
The rest can be found here:
http://www.thawa.net/gallery/view_album ... me=album94
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Thanks!
It was really easy once I figured out how I wanted to do it. The only hard part was threading the larger bolt in and that was only because it was hard to get my fingers in there.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Legacy777 wrote:That is a LHD car though.....
It's a US STi.free5ty1e wrote:That sure is a purty engine compartment on your Legacy, John. Is that a Garrett turbo I see's there?
Something more like this then, perhaps?
http://www.harborfreight.com/cpi/ctaf/D ... mber=41592
Shane
2006 Subaru WRX TR
1989 Toyota MR2
2006 Subaru WRX TR
1989 Toyota MR2
