Tranny results.
dzx
Tranny results.
Post by dzx »
Taking the transmission apart was a lot easier than some of the chevy and ford ones i've seen on the inside. Once it was apart it was easy to find the problem with the 3rd and 4th gear.
[img=http://img14.exs.cx/img14/1687/shiftfork8sz.th.jpg]
///M
'93 Legacy SS - part out
91White-T
Post by 91White-T »
Whoa, yeah I'd say that would be a problem.
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
Subaru_Nation555
Post by Subaru_Nation555 »
what part of the transmisson is that?
'06 Impreza 2.5i wagon
That shift fork's fine. Don't worry about that little crack. :)
206er
Post by 206er »
got any pics of the inside of the trans right after you split the case? just always wondered what the inside of a 5mt looks like.
and you must shift really hard to do that to a shift fork :shock: :lol:
Post by BAC5.2 »
Stock shift forks aren't that strong in the first place. Aggressive driving can break one without any ham-fisting or anything.
Be glad it was just a fork and not a synchro. It takes like 195lb-ft on the end bolt to get the output shaft out of the tranny.
That's the inside of a straight cut, synchro'd box that now sits behind my friend Jay's engine.
mikec
Post by mikec »
Mmmm..... :D
dzx
Post by dzx »
here are two of the pistons even though it looks like chunks of one, the other is in some small ass pieces.
///M
legacy92ej22t
Post by legacy92ej22t »
Holy crap, did all of this happen when your buddy let the engine overboost?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Post by BAC5.2 »
"overboost"
Your friend should be paying for all of that rebuild, by the way.
tris91ricer
Title Whore
Post by tris91ricer »
Werd.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Kelly
Post by Kelly »
What did the shift fork cost? Whered you get it?
What can you save from the long block? :shock:
dzx
Post by dzx »
Yeh, all of that happened when my friend was driving the car, no wonder it wouldnt start when i tried to turn it over.
I'm ordering a shift fork from subarupair here in boulder, its about 70 dollars for a stainless steel one to replace the aluminum.
Two of the pistons are intact with their rods, the crank shaft looks unaffected, one is smashed pretty damn good but the other one was untouched. The bearings are all good. the uppipe is fine. Other than that, the case is shot two pistons are gone, one head is ruined, two rods are gone, waterjacket above the engine has a big hole in it, oil pan is loaded with bits of metal.
///M
