STi Flywheel
STi Flywheel
Post by 555BCTurbo »
I were wondering, would the WRX STi Flywheel, Clutch and Pressure plate fit an EJ22T?!?!? I kinda found one for real cheap, so it would be a nice upgrade I reckon.
no, pretty sure it won't.
Post by BAC5.2 »
Nope, the USDM 6-MT flywheel and clutch are to large to fit inside a stock bellhousing.
You CAN mill the transmission out slightly to clear the flywheel, but that would bring the cost to above that of a WRX flywheel.
The WRX Flywheel and clutch (you have to use both) WILL bolt up, though. I'm running it now!!!11!!
Thanks guys...
Guess its good I didn't buy it then!
