Japanese oil
legacycontinues
Voluntarily Dismissed
Japanese oil
Post by legacycontinues »
Do you think the japanese use special oils for their supercars???
Do they have better oils for their better cars?
DLC
Post by DLC »
I can attest to the fact that 1) Oil in Japan is very, very expensive and 2) they use very weird weights.
I saw brands like BP, Elf and some of the more obscure names on the shelf at an Autobacs (i think) in Tokyo in 0w-40, 0w-50 and pretty much any unimaginable combination you can think of. It may be better, but i think it's probably a lot of "presents for your car", as Mike Shields is known for saying.
Legacy Central
legacycontinues
zero weight oil made from Elfs. Is that what Santa's sleigh uses? Too funny!
I ask because I am going to import a legacy TT and wonder if I should go completly JDM with it.
DLC
Post by DLC »
Oil is best when matched to the environment. If you're in the cold, hot or racing, pick an oil for the job.
Legacy Central
It's kind of OT, but Nissan developed some vegetable-based racing oil they used at LeMans. Don't know what ever happened with it.
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
they cooked fries afterwards
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
legacycontinues
friend of mine's dads truck runs off of vegie oil...it;s a big F-250.
This was a lubricating oil, though. They have kits to run diesel on old frier oil.
Post by BAC5.2 »
legacycontinues wrote:I ask because I am going to import a legacy TT and wonder if I should go completly JDM with it.
Get the car first. Worry about the oil second.
legacycontinues
I thought he was joking when he said it ran on old fryer grease...holy crap!!
Yeah, it's actually not too different from diesel. But it needs to be strained thoroughly, of course. Bits of left over fried chicken tends to clog injectors as well as arteries.
legacycontinues
do people following too closely get the urge for fries or Krispy Kremes???
I've heard it does smell like fried food, but I've never actually smelled one.
Yeah, the exhaust does smell like the food that was fried in the oil. There are a bunch of cars up here in Ithaca running on waste veggie oil.
You basically have to let it sit so everything settles out, filter it, and then heat it up with engine coolant before feeding it to the engine, so it gets closer to matching diesel fuel's kinematic viscosity. Cars with these setups typically run on dino fuel until they're warmed up, and for the last few minutes before they're shut off (so you don't leave veggie oil in the lines).
Burns cleaner and is renewable. It's nice.
206er
Post by 206er »
I think greasel setups typically run a tank heater to thin the veggie oil. Ive been toying with the idea of getting a 1.6TD volkswagen like a mk1 jetta to do a greasel on. with the injector pump turned up, a bunch of boost, and some other stuff, 40 mpg and 200 ft-lb in a 2000lb car would rock. too bad 1.6TD cars are rarer then hens teeth... :evil:
for more info on greasels
http://www.greasel.com/
