O yeah I'm three inches baby...
http://www.kymphan.net/aerosim/Stromung ... _WG_01.jpg
I'm going three inches baby....oh yeah, right into a sti exhaust
does anyone run this setup?, and if so, did you keep your resonator, is their a need for it? how much louder is it without the resonator?.
This should be fun
Frazer
04 modified XT
99 LGT Limited
99 LGT Limited
- Title Whore
What is this going on, though? 3 inches on an NA would really fuck with your performance.. It'd be loud, and not-so-fast. Might as well just push gas out your tailpipe. NAs DO require a certain amount of backpressure to flow properly, and give the right performance.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
Uh, I think he has an EJ20T swap Tristan.
That looks like a nice DP. Does it have a wastegate divider welded on or anything? Before you put it in you should get it coated with Hypercoating or some other type of ceramic. You'll be glad you did.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
It helps keep the exhaust temps hot, to keep exit velocity up and it also helps under hood temps, less heat soak.
It's worth it.
It's worth it.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
So I got the everything installed today, total cost
Downpipe $120
Highflow 3' Magnaflow Cat $40 off ebay
3' No name turbo exhaust $60
Instalation 400 taxes in.
Total ok well it about $550 all said and done, I have a 3" all the way back(desided not to go with the stock exhaust since so many people said it was not a good idea)
Impressions.
HOLY S#&T, wow does it pull, the butt dyno tells me it is way quicker, spool up is about 2700 with a manual boost controller.
And the sound, Oh baby, I think i'm going to go start it just to hear it growl, not loud, just a nice rumble
All said and done, I'm very happy. Pm me if you want any additional info.
Downpipe $120
Impressions.
04 modified XT
99 LGT Limited
99 LGT Limited
I bought it used off a guy from ottawa, who had it on his wrx, I just reset the comp overnight and what a difference, this car hauls, best mod, as in bang for buck, the car is noticably faster, even my girlfreind said "did you give this thing a tune up, its going really fast today" and she's not a car nut.
04 modified XT
99 LGT Limited
99 LGT Limited
- Lurker-King
