Actually....that screw is a bypass screw. It allows air around the throttle plate. Works exactly the same way as a needle valve does on a carburater.
I had a high idle issue. I cleaned the throttle body, which removed this sealling goo. The TB was benchflowed and adjusted with that screw to flow a certain amount at idle. When i removed the sealing goo, I changed things. I hunted and hunted until I removed the black mount for the plastic cover. It showed that damn screw. I screwed it in a little....idle came back down.
The thing is, from like 92 on.....the TB's don't have that screw. The only thing I can think of is that the 90-91 MT IAC valve didn't have the range that the AT IAC valve did, so they had to get to fine tune the TB's a little more so idle would be correct. They used that screw to do it. In 92, when they changed all models to the rotary IAC, they did away with the needle valve.
I may be totally wrong, but that's the only thing I can think of.
here's some more pics of the TB and that screw.
http://www.main.experiencetherave.com:8 ... /images/tb
