Engine turns over then a clunk and it stops...
legacycontinues
Voluntarily Dismissed
Post by legacycontinues »
As most of you know my legacy no longer runs. I would like to know why even though I am parting her out.
What to check first????
Drop the pan or yank the heads???
Heads would be quicker and the engine could stay put. Depends on what you suspect - heads will tell you top end and pistons; oil pan the bottom end.
legacycontinues
Can I pull the pan with the engine in the car?
Will removing the VC's show any signs?
