charcoal canister
charcoal canister
will any charcoal canister from a subaru work on my legacy ss? I noticed some had 4 holes on the top and my old one only had three.
///M
'93 Legacy SS - part out
- quasi-mod-o
- Title Whore
Can you get new canisters from the JY?
dzx, did your car make a sort of 'knocking' noise that resonated into the interior, like perhaps a phone or a pager was vibrating rather harshly inside your glovebox? I was told that sound (which is going on in my car) was from the EGR, which, if I assume correctly is associated with the charcoal canister, right?
Any Ideas?
Any Ideas?
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
umm... isn't it kinda important to have the charcoal canister to process the gas fumes from the tank? This has something to do also with, when filling your gas tank, why you should NOT top it off after the auto-shut off (splash detector) has stopped your pump.
Something 'bout loud 'splosions. Go boom. I'll ask my friend, he seems to know something about it as he's the one that warned me. But I think thats a good piece to have functioning properly in our type of fuel system...
Yes it is in the way for FMIC piping, but not if you lengthen the hoses and move it to the other side, which is what we had to do.
-Chris
91SS 4EAT stock, 200k mi
No, its for evaporative emissions. the charcoal absorbs the fuel vapor from the tank then when the ecu tells it to opens a valve and burns the vapors in the engine. It's supposed to ever so slightly increase the efficiency and decrease air pollution.
It really doesnt have any noticeable side effects, it doesnt make your car smell bad or decrease your gas mileage. It is illegal to remove but how many of us are running catless exhausts too?
///M
- Title Whore
EJ22 and EJ22Ts use different charcoal canisters. The non-turbos only have two fittings on top and the turbos have three. That's because the turbos have an auxiliary purge system that operates when on boost.
You can use a non-turbo canister if you remove the auxiliary purge valve and cap off the other fitting(s). To be safe, it's probably best to also put a check valve in the purge hose. That's what I did.
